SVGA Cable V's VGA Cable
Discussion in 'Projectors, Screens & Video Processors' started by Dirk_Diggler, Aug 15, 2005.
  1. Dirk_Diggler
    Dirk_Diggler
    What really is the difference? Are the connections the same? I've been told a VGA cable would be suitable for going from my sky box (via an adaptor) to my projector but would an SVGA Cable not provide better quality? I have a Themescene H30A. :confused:
  2. Dirk_Diggler
    Dirk_Diggler
    Help. I can't find what i'm wanting to know anywhere else on the net.
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Hello Dirk,
    I would say they are the same cable, both with 15 pin 'D' connectors and the same pinouts , so buy either :)
    Mark.
  4. Dirk_Diggler
    Dirk_Diggler
    Cheers, that's a releif, i'd already ordered it anyways. Just waitin on delivery now. :)
  5. Squat
    Squat
    Be carefull not to make the cable too long as an RGB signal will degrade rapidly after 6 metres or so.
    Also look at getting a good quality cable like an Ixos.
  6. Dirk_Diggler
    Dirk_Diggler
    I purchased a 10 metre one (could use a shorter one) and it was the cheapest i could find (about £20). But surely it will still be a much better picture than my current single yellow cable (composite i think) used for sky? :confused:
  7. Dirk_Diggler
    Dirk_Diggler
    I meant could not use a shorter one.
  8. Squat
    Squat
    Chalk and cheese - try the RGB lead and see you are happy with the image. Also make sure you dont have any loops in the cable as this will cause interference.
