SVCD Boot Disc
Discussion in 'Blu-ray & DVD Players & Recorders' started by devastator, Jun 24, 2002.
  1. devastator
    devastator
    May 15, 2002
    1,561
    48
    +49
    Have read that you can get hold of these, or that there is a way to make one.
    Anyone??
    PS. I know you can use TMPGEmc to replace the SVCD header with a VCD header using the MPEG tools, this then allows the stream past the firmware and to the decoder which doesn't really give a damn. Problem is that not all SVCD MPEG2 files convert OK though.
