Sutable Sub For My System!
Discussion in 'Subwoofers' started by betty02, Sep 13, 2007.
  1. betty02
    betty02
    Jun 2, 2007
    92
    11
    Hey all well you can see my current speaker set-up in my sig, ive not got an amp yet as currently getting all speakers first, what sort of a sub should i be looking to get that will work well with my system, i like bass in my music quite alot, and its in a bedroom with laminate flooring if it makes any diffrence?
    Thanks guys!
  2. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Laminate flooring will make no difference, but the size of the room will.
    Loud bass is very much easier to come by than deep bass although the average size bedroom makes both a possibility.
    As regards which sub? Tell us what sort of budget you've got in mind.
    Russell
  3. betty02
    betty02
    Jun 2, 2007
    92
    11
    a very cheap one lol, i mean ive not got an amp yet so really am after the cheapest but best for my room, i would say its around 10-11ft square the room so could base it arond that pleasee guys?
  4. theone
    theone
    Nov 25, 2006
    177
    2
    Nottingham
    +7
    For £200 I bought the BK XLS200 Sub and it gives cracking Low and powerful Bass. I use it for Movies and Music (anything from Dance-Rock) and it always delivers with no problems or delay. My room is about 12 x 14 ft and more than capable to fill the room with plenty of Bass, when I first turned it on it made my doors rattle with the Bass! :thumbsup: The Neighbours probably thought there was an earthquake!
    Build quality is excellent with a great finish (I have it in Cherry) and it weighs about 12.5kg. I comes with rubber feet (perfect for your floor) and spikes.
    I honestly cannot fault it and would recommend it to anyone.
    Hope this helps.
    http://www.bkelec.com/HiFi/Sub_Woofers/XLS200-DF.htm
  5. MARKAFN
    MARKAFN
    Nov 23, 2007
    2
    Try the mj acoustics pro 50 sub , and you can buy a high level lead so you dont need a av amp u connect it to your speakers.
