Survivors Series Two - now released
Discussion in 'TV Show Forum' started by BigAde, Oct 4, 2004.
  1. BigAde
    BigAde
    Jul 22, 2002
    964
    East Sussex
    +23
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    yeah I quite liked it. Probably buy the second series.
  3. guysie
    guysie
    What a classic series already got series 1 bought series 2 from amazon anbd if you are first time register with amazon they knock £3.00 of made it 34.79 :clap: :clap: :clap: :clap:
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    50quid in HMV ! I bought it from play instead.
  5. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    I paid £37.99 to PLAY.
    Don't let the second season put you off.Some episodes reach soap opera levels at times.But it picks up in season 3.
    The packaging mentions that the discs contain scenes missing from satellite transmissions,but I can't find anything to indicate which scenes are extra.I know UK Gold used to often miss scenes on the repeat,or even on the first showing and restore them on the repeat.
    The booklet is very nice and the quality is good,but I found the interviews were lit in a very irritating fashion.
    The original UK Gold transmission of Lights of London suffered a technical breakdown so your tapes may still have that in it if you were not watching at the time.It was a year later before another repeat enabled me to correct the fault.
    As a fan I thought the series changed dramatically in season 3,with pluses and minuses.Ian McCulloch and Denis Lil disliked each other so much that this is what forced the series to go the way it went,with Greg off in one strand,while Charles and the rest were elsewhere,which made for some dramatic stories like the rabies one with Charles,but it was a disappointing ending,even if McCulloch did get to write his own,very good exit.The series went on for one episode too long and the last but one would have been a fitting climax-the last one seemed tacked on as an afterthought.However,I look forward to season 3 and it would be nice if McCulloch and Lil could get together for that one.I am not aware of whether they have even met since 1977
  6. phelings2
    phelings2
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    Watching the second series now and frankly its either laughable or like watching paint dry. Ian McCulloch has to be the worst actor ever. (poor mans shatner!)
