Surround System
Discussion in 'AV Receivers & Amplifiers' started by bv2312, Sep 10, 2007.
  1. bv2312
    bv2312
    Sep 10, 2007
    Hey all!!
    First Post and need some advice....
    I have A
    TV (like everyone else a bit old has 2 scart sockets will be changing to LCD)
    DVD Player
    VCR (don't ask lol)
    NTL/Virgin Media Analogue Box (Will Change to digital when they switch off)
    What i would like is a set of speakers say 5.1 price is 100 - 200 and watts doesn't need to be huge either but i want to be able to keep using the speak even if i change dvd, set top box, tv etc so i'm not sure if i should get a dedicated speakers and all my kit get connected to that. what is the best connection for sound..?
    Any help would be grateful!
  2. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    Have a look at the Yamaha AV 69 kit. It's around £200-£250, but its the cheapest decent budget amp & 5.1 speaker set.
  3. bv2312
    bv2312
    Sep 10, 2007
    Thanks for your reply.... if but my budget to say £300 what would be a good set? plus i couldn't find the AV 69 anywhere
  4. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
  5. bv2312
    bv2312
    Sep 10, 2007
    thanks for your help!
