Surround system cables
Discussion in 'Cables & Switches' started by polyvision, Jun 26, 2004.
  1. polyvision
    polyvision
    I have a sony surround system and needed to extend the cables. The standard cables are silver and have a clear jacket. What type of wire could I use to extend the cable? Would copper cable do or would it cause problems due to its resistance? Also, whats the best method to connect 2 wires?
    tia
  2. Kramer
    Kramer
    I'd suggest replacing them with longer cables rather than joining/extending.
    Cable type won't make a difference & there's lots of reasonably inexpensive speaker cable around. Have a look at some of the sponsors' sites for ideas/pricing.
    :smoke:
  3. polyvision
    polyvision
    good call
    but does ofc cable make a difference over standard copper cable?
  4. Kramer
    Kramer
    OFC (oxygen free copper) is supposedly of higher quality but with all things like this is as much a marketing tool as anything else.
    Depends very much on your system but any decent quality speaker should be OK. I'm sure others will give names/prices later as I'm off out now for a drink to celebrate the departure of george w. from our shores :thumbsup:
  5. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    If your Sony system is a DAV all in one I doubt whether the difference between OFC and copper cable will be audible.
