Surround Speakers
Discussion in 'Home Cinema Speakers' started by Nixon, Aug 16, 2003.
  1. Nixon
    Nixon
    Hi all, I have a maranzt SR4300 for my amp and a pair of Celestion Ditton 44's for my lef and rights, I don't have center, or any rears. I am preferably looking for some tall rears although small ones would be fine. My center I think i'm going to hold back on for a bit because there not that important are they? My budget is around £100. this amp has 6.1 so I would have my two fronts yes, then my two backs, then my center and would I then have another speaker inbetween my two rears? Any advice would be greatly appreciated.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I would try and save a bit longer...... in my view a centre is essential for a good system..... though some will disagree...... the soundtracks are engineered with a centre in mind so its wrong not to have one.
    Ad
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    if ur gonna be watching dvd's etc. then i would get a centre,as this is where most of the vocals/high end sound comes from. imo, if i were you id get left/right speakers and go for the centre, then get some rears at a later date or some cheaper ones( wallet permitting)
  4. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    you are gonna have to save a heck of a lot to find a centre to match your ditton 44s (big mothas of speakers). First port of call would be a big old centre from ebay (old Jamo, Tannoy etc) maybe, and you should be able to find some old floorstanders from the same place for rears(Kef Codas, Tannoy 603s, Mercury M3s, Mission 702es, 733s)...
    edited to add:
    theres an ex-demo JBL Centre down from £200 to £125 at www.edge-sv.co.uk which would do the job very well. They are a good shop to deal with- bought loads of stuff off them
  5. Nixon
    Nixon
    So your pretty much saying that I need to get some centers and rears to match my dittons 10 inch sub, 13" Width, 30" Height. So would I be best going for some rears at the moment or get a center OR get my rear center baring in mine my around £100 budget. I use it mainly for music but will also be using it extensivly for movies once surround is at least basic.
  6. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    yes we are ( i think i speak for above posters ;) ). The dittons dont' have a sub, they have a woofer, not a subwoofer. Theres a difference.
    get a centre first, as it handles 50% of the action during a movie (fronts 25%, rears 10%, rear centre 5% and sub 10% ROUGHLY) then get a set of rears, then rear centre, then a whacking great sub, to give you more punch (and yes you will need one- that sr4300 isn't exactly a powerhouse, and the ditton 44s aren't the most efficient speakers man created (or machine))
  7. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    68
    Leicester
    +56
    If your sitting directly between the left and right speakers in their sweetspot you may find you system doesn't need a centre. I'd be prepared to say that centres can cause a lot of damage due to the differences they create in the front soundstage (even if they are supposed to match). However, if you've got lots of people watching or you have to sit off centre then you've not got much choice. I'd agree with Jamo and Tannoy as a good place to start and add in Paradigm.
    Look to pay about £40-60 and if you really want to experiment buy several secondhand and keep the one that works best. Even if you lose money when sell them on you'll still have spent less than if you'd bought a budget centre brand new.
