Surround speakers???
Discussion in 'Home Cinema Speakers' started by activeservo, Mar 28, 2003.
  1. activeservo
    activeservo
    What is the ideal placement for surround speakers in a small room????Approx 10ft x 9ft x9ft.At the moment they are either side of me about 2ft above ear level pointing down ,I sit closer to the right surround speaker through lack of choice.Any ideas on speaker placement and receiver adjustment to obtain that perfect enveloped surround effect.Thanks in advance.:smoke:
  2. Brad_Porter
    Brad_Porter
    My room is also small and the best sound I got from my sorrounds was to have them as high up as possible and facing each other. Idealy you should be in the middle.
    I have mine about 4-6 feet above my head and calibrated with a SPL. It isnt perfect but it does take away that 'sitting right on top of your ears' issue.
