Surround speakers!!!
Discussion in 'Home Cinema Speakers' started by activeservo, Feb 3, 2003.
  1. activeservo
    activeservo
    I've just bought some speaker brackets that you can adjust{up,down,left,right}.I was thinking of placing them high up in the corners either side of me.I sit through lack of options on the back wall,I'm trying to create the effect that they are far away to make a more spacious surround field.So I thought I 'd place them right up in the corners as close to the ceiling as I can get, then tilt them down towards the listening area and them input the distances on the receiver.I know people say that if you point them towards the back wall it gives a more diffused effect, but it doesn't look very nice when you walk into the room and see the back of the speakers with the cables hanging out.Any advice on how I can achieve a more deeper sound field on the rear channels would be very much appreciated.Thanks in advance. :smoke:
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Get a couple of mates around... they're not great speaker stands...but can be great for testing out whether rough positions do/don't work_before_ you get the drill going.
    spence
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,979
    Berkshire
    +110
    Don't place the speakers too close to the wall or ceiling. They will get too much bass reinforcement and the sound will run along the walls/ceiling and not spread out enough. Place them about 30-50 cm from the room boundaries.
