Surround Speakers Up to £400
Discussion in 'Home Cinema Speakers' started by Michael Belej, Jul 6, 2001.
  1. Michael Belej
    Michael Belej
    Any advice on the best set of Av speakers (small units only) up to £400. Richer Sounds are doing SOny's SAVE705 for £399.
    Help! :confused:
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,626
    United Kingdom
    +2,233
    Avoid the Sony package, theres much better speakers available. Richer Sounds have the following :
    How about
    Kef Cresta centre - 99.99
    Kef Cresta 2 - 149.95 fronts
    Kef Cresta 1 - 99.99 rears
    Then you still have 50 quid to go towards a sub at a later date.
    Or a Mission setup
    Mission 70 c1 - centre
    Mission m71 or m72 as fronts & rears
    again with change towards a sub.
    I think Missions 6 pack is available as well for about 400 quid but you´ll need to check the price out.
    The prices quoted are on www.richersounds.com
    if you want to check them out.
    hope this helps you
    Jase
  3. george1138
    george1138
    Given the choice of the above two packages I would go for the KEFs. Great speakers. :cool:
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Or some Tannoy M(x) perhaps, M1 x4 + Mc for example.
  5. Guest
    Ive got the Mission 6 pack and it rocks. 5 smallish speakers and a sub.
    if you shop around it can be got for less than £300 squid
  6. Michael Belej
    Michael Belej
    Thanks All - Great Advice
    Went for the Mission 6 in the end at £260. Speaker size really important.
    Any advice re an affordable speaker cable?
    Thanks Again Hombres
    :D :D :D
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The best cable for these speakers would probably be QED Qudos/Original, I think it's £3/m (yes I do sell it so I should know... but I sell more Chord)
    Rick
  8. DPS
    DPS
    Mike where did you get the Mission 6 pack from for £260.My budget is tight and Ive heard great things about these speakers the cheapest Ive found is £295.
  9. Guest
    I use QED silver Aneversary on the front sound stage @ £5 p/m and QED Qudos micro on the rears @ £2 p/m with my Mission six pack.
    sounds fantastic
    Also get a good sub woofer cable, makes all the difference
  10. Michael Belej
    Michael Belej
    Gladiator_2001: Thanks for the advice.
    Technoir: www.empiredirect.co.uk have the Mission 6 for £259.99.
    Bargain!
    Mike
    :D
  11. DPS
    DPS
    Thanks alot Mike.
