Surround speakers - necessary?
Discussion in 'Home Cinema Speakers' started by Jonesthegas, Jan 15, 2003.
  1. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    749
    Newcastle upon Tyne
    +41
    I'm finding the decision of what speakers to buy almost impossible. At a particular price range and spec, there are only a handful of amps and dvd players to choose from and there's probably not too much between them. However, there is a bewildering array of speakers to choose from and demoing them all is not possible in Newcastle upon Tyne.
    Here's my question.
    I read a post by Eric who suggested buying a set of QUAD 11Ls as a possibility for an AV system. In my case, this would mean 7 of them with 1 acting as a centre and 4 for surrounds. How would this solution compare to dedicated dipoles and centre speaker? Do HiFi speakers make capable surrounds?
    I know that surrounds are supposed to "spread" the sound better but in a 7.1 setup is this an issue?
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    you have more of a chance than people living outside major cities.
    Uncle Eric doesn't like using dedicated centres because of the diiferent tonal qualities inherent in using a speaker of a different size and shape with your left and rights, no matter if they do use the same drivers.
    as for the dipole/monopole question, its a matter of personal taste really. do you want directly radiating accurate sound from a standard monopole or the extra atmospheric dispersion provided by the di/tripoles?
    and could I ask for expert judication on this 7.1 matter, just because you have two surround backs for the single surround back channel surely that's still 6.1 using 7 speakers and not true 7.1
