Hi all,
I am planning to upgrade my surround speakers (I'm currently using some surround speakers from an old AIO system) and add 2 rear speakers to make a 7.1 setup. My room is 20' x 12'.
I have large fronts (MS 906i), centre (MS 905i) and sub (MS 309). What would you recommend for the 4 surround speakers?
I was thinking of the 902is but these are bookshelf speakers and to have 4 of them at the back of the room seems a little excessive given that most of the sound comes from the front. Instead, I am now thinking that I should get four 302's.
What will I be losing by having the smaller speakers? Is the benefit of having the larger speakers worth the extra cost and space they take up?
Thanks, Benwolf.
Thanks, Benwolf.
