Surround speaker positioning - this advice is wrong, isn't it?
Discussion in 'Home Cinema Speakers' started by FlimsyFeet, Dec 31, 2003.
  1. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
    Now I know for Dolby Pro Logic the surround speakers should be positioned 2-3 feet above ear level, so the sound is less directional. I always assumed it was the same for Dolby Digital 5.1?
  2. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    I think it depends on how far the surround speakers are away from the listening postition. If they're say 10 feet away, then ear level would be fine. But for most domestic situations, a few feet above ear level is preferable because you'll have more diffused and less direct sound. That's all MHO and by no means the accepted standard. But if you look at any cinema, you'll notice that the side surround speakers are mounted fairly high up.
  3. fred123go
    fred123go
    Sep 16, 2003
    1,040
    39
    Cobham, Surrey
    i have tallish stands for my rear speakers, as at present, i have slanted walls and obviously impossible to wall mount them.
    Although does anyone has a link to any really tall stands?, ie above ear level, then that would be great.
    fred
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,253
    Southsea, UK
    +85
    I have my surrounds about 3 feet above listening level. This is within the boundry's of Dolby Labs reccommended positioning for Dolby Digital setups. I am more than happy with my surround sound in DD or DTS but I do always feel that I'm not hearing as much surround as I would like in Dolby PL/PL2.
