Surround Speaker Placement
Discussion in 'Home Cinema Speakers' started by Paden, Jun 14, 2001.
  1. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Hello all!
    Does any one have their rear speakers position thus:
    [​IMG]
    Have you had any luck with options C or D?
    Cheers!
  2. Jase
    Jase
    Mar 16, 2001
    10,701
    United Kingdom
    +2,416
    Ive got my rears as in fig A and my rear centres as in fig B although theyre about 5-6ft behind the listening position.
    Cant say i´ve ever tried the other 2 positions, might give it a go though to see what it sounds like.
    cheers
    jase
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I am using option "E". ;)
    Similar to "B" but speakers further apart as mounted on brackets on the side walls and slightly toed in.
    Used option "A" at my old place, too close and sound wasn't balanced as it depended too much on your position on the sofa.
    Later I mounted them below the ceiling (couldn't hang them any deeper due to the beam) like in option "B" where they hang too high and the sound was spreaded out above you. No good.
    When I finally moved I ended up with the above layout, yet not perfect as there isn't enought space to the rear between the sofa and the speakers but close(r).
    Next time we will get it perfect ... :D
