surround speaker package
osmyth
I am about to buy a dvd recorder to replace a video and need to add an amp and 5.1 speakers. There seems to be a few ways of doing this so would like some advice please.
1. get a speaker package with the amp built in, like the Sony HTBE1.
For - price, got a good review
Against - quality?
2. get a separate amp/receiver and separate 5.1 speakers.
For - could add other inputs (not too bothered about this though), better quality?. Against - more expensive.
3. get a dvd player all-in-one package.
Like the look of the Panasonic SC-DT100, but could do with just the amp/speakers.
For - could copy DVD to DVDR (with correct scart). Against - will have 2 players.
any thoughts?
cheers, Owen.
J
juboy
If it's the best quality per pound spent and flexibility that you're after, number two of your options is really the only way to go.
balders
I'm in a similar position - got a Tosh 36ZP18 TV, and am currently using the speakers that came with the TV to watch DVDs in DD. They're OK, but I;m getting to the stage where I want something better.
Thinking about option 2, what receiver/ speaker packages can people recommend bearing in mind :
- I'd like to keep the cost < £500
- I don't want massive speakers taking over my living room
- I don't want black speakers as they will be too imposing
- I don't need a hugely powerful system (rooms only 4m x 5m)
Any ideas?
Thanks,
Balders.
J
juboy
You could just about squeeze a Marantz SR4200 and the Mission Cinema 72 A/V Speaker Package in Beech and Silver for £500 with some careful shopping.
You'd still need a little extra for cables etc. and would at some point probably want to add a subwoofer but the above would be one solution to meet your current requirements.
7
7ThGuest
Hi Balders,
If you want something quite small and gucci in silver, I am about to put 5 Elac Cinema Sat 1 speakers. They are only 3 weeks old hardly even run-in. They cost me £50 ea (looking for £45 ea + p&p) The only reason I am getting rid of them is because I got a cracking set of floorstanders from someone on the forum so I am now going bigger.
They have won several awards, click on the link below:
http://www.elac.com/de/tests/2002/whifi10_02_cin1.html
The missus won't let me keep 2 complete sets!! :(
Regards
7ThGuest :)
balders
Thanks, 7th. I'm not quite in a position to buy yet, so I won't be able to take you up on your offer.
Good luck with the sale though!
Balders.
