surround sound
Discussion in 'Home Cinema Building DIY' started by newcomer, Nov 20, 2004.
  1. newcomer
    newcomer
    is there a way of setting the speakers for a room so that although the room shape is not perferct you can adjust speaker volume to overcome this.
    i have the DENON 550SD
  2. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    think ure find something called speaker distances, which u should be able to set on the reciever/amp etc. my denon automatically works this out :)
  3. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Roguey is correct, you should find an option to set either speaker delay or speaker distances in the setup menu for your amp (assuming your amp, like the Denon, doesn't have an auto setup option).
    John
