Surround sound???
Discussion in 'Home Cinema Buying & Building' started by j501, Nov 28, 2010.
  1. j501
    j501
    Aug 27, 2010
    I have a Sony DAV-S500/C700 avsystem and the surround sound onlyworks through the DVD. Can I play the tv through the speakers and if sowhat doi need to do?
  2. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    You will need to connect an audio cable from the TV to the h/c system. A quick google revealed that your h/c system has both optical and phono inputs.
    Check the rear of your TV and the manual and look for:
    Optical audio out (spdif) - Optical cable (fisual pro at audiovisualonline is fine at £5)
    Analogue red/white phono out (make sure it's an output not an input) (profigold are fine at £10)
    Alternatively some TVs output audio over SCART so you would need a switchable SCART adapter (tvcables sell them) set to OUT with a phono cable from the adapter to the analogue phono input on the h/c system.
    Then simply select this external input on the remote and you should hear your TV audio through the speakers.
  3. j501
    j501
    Aug 27, 2010
    Thanks for that, top man. One more thing though, I would like to hide the DVD behind the tv on the wall (it's on a tilt,turn bracket with room behind it), do these DVD layers have to sit flat or can they be stored vertically, if you no what I mean??
  4. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    It depends on the player. It should be pretty obvious whether the player is designed to be sat vertically. The manual should also tell you.
  5. j501
    j501
    Aug 27, 2010
    I plugged in my speakers and only 2 seem to work, the other 3 just have hissing coming from them, I've swapped them over so it's not the speakers. Any ideas?:lease:
  6. KCooperman
    KCooperman
    Mar 30, 2009
    250
    +35
    Its because you are listening to a stereo source. The hissing you hear is just interference.
    Press the Pro Logic button on your remote to play it through all speakers.
  7. j501
    j501
    Aug 27, 2010
    Your some man!!!!!
