New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
I have finally wall mounted my 436XDE and need to get a decent surround sound system which matches the black finish of the pio.
Can anyone recommend a all in one system to complement it ?
Got a budget of about £250.
Normally, one would look at the same manufacturer for a "match" in terms of design and in this case it would probably be the Pioneer DCS 360. However, this system is severely restricted in inputs, effectively rendering it a DVD only system (no optical/coax), so you can't run SKY or anything else through it.
Have a look/post on the "all in one" forum and you may get more assistance there!
