Surround Sound System for PS5
BK77677
I'd like to buy a 5.1 surround sound system to use with my PS5, PC and Switch. Prefer a traditional home theater setup with a receiver but would consider a soundbar. It's needs 4K compatibility for the PS5, I need 2 or more HDMI ports (preferably 2.0 or 2.1) and an optical port. I need small speakers as I don't have much space, but I'm more concerned with finding the right receiver to use with the PS5. I've seen comments where people are having problems using some receivers with the PS5 (particularly the Yamaha 495OU), so any help would be greatly appreciated! I live in the US.
Darbo
I've got the Denon 2700, it's great, it does have the 4k/120 problem that the recievers from last year have but it's not been an issue with ps5 as it outputs at 1080p with 120fps.
It's got more than enough hdmi inputs as well as two outputs, give it a look.
BK77677
Thank you. I need to run the PS5 in 4K through the receiver and out to my monitor (not a TV) using HDMI. The monitor is an LG and does 60 fps at 4K. In addition, I need to run my PC into the receiver, most likely using an optical cable. Do you think I could achieve this with the Denon 2700?
Darbo
Absolutely, here's a pic of the rear of the amp, 2 optical in, 2 component in, 1 component out, 6 hdmi in, 2 out.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
