Surround sound setup for £350ish?
Discussion in 'What Speakers Should I Buy?' started by Munkee6002, Sep 1, 2013.
  1. Munkee6002
    Munkee6002
    Nov 20, 2006
    89
    11
    +4
    Hey all,
    I've had a look through the forum for some advice, but haven't yet found a good answer to my question...
    Having just redecorated my living room, I will be mounting my 40 inch Sony Bravia on the wall and will be needing a surround sound setup, to avoid using the crappy speakers built into the TV. Problem is, I only have £300-£350 to spend on both the speakers and an AV receiver.
    Can anybody recommend a solution please?
    I was looking at the Boston Acoustics Soundware XS 5.1 SE which are going for £220 on Richer Sounds, which would leave me just £100ish for the AV receiver. I can see the following AV receivers on Richer Sounds:
    Pioneer VSX322
    Sony STRDH520
    ...both for just £100.
    Would this be a decent solution?
    I will be hooking up a Sky HD box & PlayStation 4.
    Thanks for any advice you can give.
    Munkee
  2. DrGekko
    DrGekko
    Feb 21, 2007
    4,536
    3
    3
    107
    West Mildlands
    +470
    If you could stretch you budget by another £100, how about this?
    Denon AVRX500 with Canton Movie 90 Speakers
    Otherwise any of these would suit your budget:
    AV Systems
    Main thing is getting a decent amp and spending less on the speakers - these can be upgraded any time.
    I use a Marantz 1402 Av receiver along with Canton 70 cinema package - suits me down to the ground for our TV lounge - I'm sure you can pick up similar items used within your budget. Q-Acoustics are always a popular choice and I believe quite easy to sell on.
