Surround Sound Setup Advice (Corner TV)
Discussion in 'Home Cinema Speakers' started by pgrayem, Feb 5, 2009.
  1. pgrayem
    pgrayem
    Feb 5, 2009
    7
    Hi All
    Taking delivery of the Samsung NT-TZ315R today so after some help on speaker placement.
    Heres a pic of the living room
    [​IMG]
    [​IMG]
    we are actually changing the tv unit to a proper corner one so the tv will be right in the corner
    any help much appreciated
    thanks paul
  2. swiftpete
    swiftpete
    Sep 30, 2006
    5,185
    Notts
    +1,294
    That's exactly the same layout as my lounge. I put the sub behind the tv, the front and surround speakers just in front and to the side of it and the rear surrounds either side of the sofa on the left, which is the main one in my lounge. That's the one I use for tv watching. If you do the same, whoever sits on there will have the proper surround effect. Anyone sitting on the other will still hear the tv. Depends on which sofa is your favourite.
  3. Grr Argh
    Grr Argh
    Oct 30, 2008
    157
    +22
    Hi there,
    I wish I could give you a great layout for the speakers with that room configuration but with that lounge (from what I can see) I'd definitely be inclined to rearrange. Something like the attached image.
    Speakers in red, TV solid black. It's just a rough configuration of course, the sizes will be all wrong but that's how I'd have it I think. The rear speakers right in the back corners would be best but I don't know how attached to that corner unit you are hehe. Rear speakers aimed at the sofa opposite the TV.
    Hope this helps!
  4. pgrayem
    pgrayem
    Feb 5, 2009
    7
    @ swiftpete
    tbh mate the one we use the most is the one on the right (thats a three seater, the others only a two), so would probably try to the rears around that sofa
    only problem there is the door on the right, running wires
    @ grr, argh
    thanks for taking the time to show me your idea pictorially
    the problem is where i took the picture from is a big alcove so the two seater would just be placed in the middle of the room.
    i asked if i could put the two seater in front of the window, the boss didn't like that!!!!!
  5. swiftpete
    swiftpete
    Sep 30, 2006
    5,185
    Notts
    +1,294
    You could run the cables over the top of the window behind the curtain rail. You can get slimline white cable that wouldn't really show up too much against the walls. Or I saw this hollow trunking stuff on ebay the other day that lets you put the cables inside it to hide it.
    Or under the carpet? That'd probably be the tidiest way.
  6. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
