Surround Sound Settings?
Discussion in 'Home Cinema Speakers' started by jaspain, Mar 25, 2006.
  1. jaspain
    jaspain
    Mar 24, 2006
    402
    Telford
    +7
    Does anyone use something like a THX Optimizer and can post the best and correct settings for a 5:1 surround sound. I want to make sure I get everything as best as possible for the arrival of Sky HD.
    Jason
  2. Dr_Techno
    Dr_Techno
    Hello
    Its worth buying a Sound Pressure Level meter for setting up. It makes a big difference.
    You dont really need a special disc.
    Just use the manual level settings in your AV amplifier and adjust them with your SPL meter.
    Best regards
    Andy (TOKYO TV) Bristol
  3. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    A lot of people swear by the Avia disk, I haven' tried it but I have one on order. No one be able to bost 'the best settings' as each system and room is different. You will have to set your system yp to your room / kit.
