Surround sound set-ups
Discussion in 'TVs' started by Richard Morris, Sep 27, 2003.
  1. Richard Morris
    Richard Morris
    Is there anywhere on the net that I can find info on sorround sound set-ups - ie how I should position the speakers for maximum effect ? Every time I search I just get loads of sales sites. Not had any previous experience of this but looking forward to it !!
    I have a rectangular room and the new Tosh 36ZP38 (with 5.1) will have to go into one corner (fireplace to one side, patio window on the other side).
    Also, do people tend to just buy 2 speaker stands (ie. for the rear sound) and lay the 2 front speakers on the floor ? I'll probably buy before the TV arrives a couple of weeks.
    Any advice would be appreciated. Are stands universal or should I be buying the Toshiba recommended stands ? Anyone with any particular preferences ?
    Thanks.
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
  3. Richard Morris
    Richard Morris
    Thanks for the tip.
