I'm after a bit more advice. I now have a lg lm620t which incorporates hdmi arc. My problem is I can't get it to work.
Basically, I have the tv (lg lm620t), sky hd box and Sony bdve280 home theatre system (also arc compatible).
The home theatre is connected from its hd out (arc) into the hd1 (arc) slot on tv. Blu rays surround sound work fine.
The sky box is then connected via hdmi into the tv (so I can watch sky without surround system on). Which works fine.
I also have a digital cable connection between sky hd and home theatre (for watching movies through external speakers). This also works fine.
The only thing that I can't get to work is the audio through the arc. Being a smart tv I have it set up to view all my pc media libraries. I would like to be able to listen to the music through the external speakers. However, whichever options I set on tv and home theatre I can't get the tv sound through the home theatre (it works fine through the tv speakers).
I assume there is a problem with the arc feature? Do I need a certain type of hdmi cable?
