Surround Sound Problem!
Discussion in 'Home Cinema Buying & Building' started by r3shs, May 26, 2005.
  1. r3shs
    r3shs
    I have the SONY KD-28DL11 and the Surround Sound system... but it only works when playing a DVD - not when watching SKY.. what could be wrong?
  2. johndon
    johndon
    Feb 3, 2002
    1,925
    48
    +88
    Do the have the the sky box connected to the surround system via the red and white phono connections or does the Sky box only connect to the TV via scart?
    If it's connected via the phone connection and, if the surround system can support Dolby ProLogic or Dolby ProLogic II, then you should get some degree of surround sound when watching Sky.
    John
  3. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    Hi r3shs, welcome to the forums.
    What surround sound system is this?
  4. r3shs
    r3shs
    It is only connected from Sky Box to TV.. is that the problem?
  5. r3shs
    r3shs
    I have the following Surround Sound System - Sony DAV-SB100
  6. r3shs
    r3shs
  7. inzaman
    inzaman
    Dec 16, 2002
    7,875
    Derby
    +929
    I have moved this thread to all in one systems for you as it is more relevant to that category :)
  8. johndon
    johndon
    Feb 3, 2002
    1,925
    48
    +88
    Yes, to get sorround sound, you'll need to connect the Sky box the surround sound system (if you can).
    There are two ways to do this:
    1. Connect the red and white phono sockets on the back of the Sky box to phono in's on the Sony. When you want to listen to Sky in surround, you'd need to select the relevant input on the Sony depending on the phono input you have used. This option will give you Dolby ProLogic II
    2. If you have a Sky+ box and if the Sony has an optical in, you can connect the two via an optical lead which will give you Dolby Digital 5.1 on those Sky channels that support it and ProLogic II on others.
    HTH
    John
  9. r3shs
    r3shs
    Thanks John I will give this a go!
