Surround sound & plasma
Discussion in 'Cables & Switches' started by stoobydale, Jul 22, 2004.
  1. stoobydale
    stoobydale
    Jul 17, 2004
    116
    +4
    Hi can anyone please advise? I have a Teac Ref 500/550 system and have just bought a Panasonic plasma screen but I need some advice on speaker cables/set up. I need all new cables as I have moved house and had to leave the others behind as they were all below the floor. I have just read an article on making your own cables from Cat 5 cable and I am going to have a go at this for the 2 side speakers and the front but I think this is probably overkill for the rears, what do you think? My speakers are not fantastic they are Teak 5.1U, what would be a suitable (fairly cheap) wire for the surrounds?
    Thanks.
