Steve Adlem
Want to buy a surround sound system. Never had it before, so anything is going to sound amazing and to be honest I wont know the difference.
Can you advise some cheap (under £350) and cheerful options.
Current setup is 42" Panasonic plasma, Humax Freeview PVR (connected via scart and has optical output i think), PS3 (connected via HDMI).
Dont really care whether it is seperates or all in one but the only thing I cant have is receiver type unit higher than 14cm as the tv stand gap wont accomodate. Subwoofer box will go behind tv.
Hope that makes sense ?
