Hi All
Iv'e got a Panasonic Tx-50DX802b and a Yamaha DSP-AX761 Amp. I'd like to extract the 5.1 audio from the TV ARC signal to the amp via a digital connection, toslink. The amp only has hdmi 1.2a so no ARC. I am sure this isn't the first time this problem has been posed to the board, so I am asking for a solution which is automatic and effectively transparent. Other people have to use the tv, so simple is the way. Everything input is attached to the Amp, the surround is simply to allow the internal tuners, apps etc to be in true surround. I would still like the TV to behave as a stand alone unit when the amp isn't on/in use. I know this is simple but I just want to be sure I'm not barking up the wrong tree with an overly complicated solution. No I can't get away with connecting the TV to the Amp with toslink directly, too many untidy cables etc.
Thanks Dave
Thanks Dave
