Surround sound from everyday Sky???
Discussion in 'Sky Digital TV Forum' started by SimonBut, Jun 16, 2005.
  1. SimonBut
    SimonBut
    Nov 12, 2004
    41
    Hi, I'm using Sky + into Pio Ax5ai and 435 XDE.
    My question is simple - are any of the 'standard' i.e not movies but Eastenders etc. broadcast with any sort of prologic coding??
    I don't seem to be able to get anything but I'm certain I could from my old Sky box. Any thoughts on if I've the amp set wrongly?? I've cycled the settings but to no avail
    thanks
    Simon
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    My amp does dolby pro logic II and I get 'surround' sound from a lot of programmes on Sky (Pace v2 Sky+ box into an Arcam AVR300)
    John
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If you can get stereo, you can get pro-logic.
  4. SimonBut
    SimonBut
    Nov 12, 2004
    41
    If I set to prologic II movie, I get a signal, but its not pro-logic, its a split of the stereo signal. So as far as everyone is concerned, there is a prologic signal encoded in normal transmissions??
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It obviously depends on the source material. Pro-logic is a very simple encoding process involving phase reversals, and since this sometimes happens naturally, it is often difficult to tell whether you are listening to "proper" PL unless the broadcaster tells you.
  6. SimonBut
    SimonBut
    Nov 12, 2004
    41
    Cheers - that's what I thought.
