Surround sound for my XBOX
Discussion in 'Xbox Forums' started by Dirty Sanchez, Sep 27, 2003.
  1. Dirty Sanchez
    Dirty Sanchez
    Im looking for a surround sound set up for my XBOX, anyone got any suggestions for a good system for around £150 P.S Soul Calibur ROCKS!!!
  2. mrmcdean
    mrmcdean
    Jun 25, 2003
    733
    +27
    A friend of mine recently bought one of the Creative labs systems for his X Box - I think he got it for £150.00 with cables included (check just in case & make sure its the one with the digital decoder). Sounds pretty good for the money. I have a similar setup without the decoder on my PC and I have no complaints. I think you can run a couple of things through it not just a single piece of kit.
  3. Azrikam
    Azrikam
    I bought a Scan AV6 system for my PC, and it gives great sound for the price. Scan currently list it at £163.00, but you can often find it on the Today page for cheaper. (just check back each day, as they rotate many of the products)
    I'm using mine with my XBox as well, and Halo never sounded so good!
  4. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    I've been wanting to buy a surround sound kit for about 6 months now. I finally placed an order for a nice Yamaha kit from Empire Direct at the end of August but was later told that they wouldn't be restocking the product for a few weeks, so I cancelled it.
    I'm not sure what I'm going to do now as I want to buy a new PC but would like to buy a nice separates kit. It's all getting a bit too expensive.
  5. Dirty Sanchez
    Dirty Sanchez
    Thanks guys, will check those suggetions out coz I need a decent sound system before HALO II comes out!! P.S Have you all seen the 8 minute HALO II demo...looks AWESOME!!
  6. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Unfortunately mate, you can't get a good system for £150. Only a **** poor one, and i doubt with speakers touching anywhere near 5wpc rms.
  7. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    I wouldn't go as far as saying a **** poor one. You can get a system which sounds good to the novice surround sound buyer but lacks any kind of intergrity to a surround sound expert!
  8. Azrikam
    Azrikam
    Yeah, my system sounds great to me. It doesn't have much in the way of power, but since I'm playing in a 6X8 room, it's not an issue.
