Surround sound cable location query
N.A.V
Hi All,
I'm currently renovating my room layout for my house and I'm after a bit of advice.
Would you recommend running the speaker cable for the surround sound system within the wall space and ceiling to avoid having cable runs across the room?
What cable would you recommend and any other advice on how I should go about the set-up would be appreciated.
MarkP80
NAV,
Cable routing depends on the specifics of your house and where you are placing your equipment.
You can go under the floor (unless it's concrete!) if that suits your speakers and equipment location. Or behind skirting boards. Or use flat cable and simply go under carpets if you like.
Your best bet is to have a think, and post your proposals, then I'm sure you will get some comments. It's a bit difficult to make suggestions otherwise. :smashin:
Cheers,
MarkP
Oscarp
NAV,
Or you can run it on top/ under a dado rail or above coving.. basically anything with a a lip on it....
As for getting it to the "lipped coving" (as in my case), I just used 16x16mm trunking up the corner of the wall and then painted. Pictures will be posted in 3 weeks (once its all done)
OscarP
lsba02853
If you put it under carpets, make sure it's away from the gripper rods.
I did this about a year ago and the carpet fitters decided to sever the speaker cables, the Barstewards.
lsba02853
Totally up to you but I think they're Fugly.
If the speaker cable is the usual standard stuff why not get some small trunking and paint it the same color as the walls?
You can use decoraters caulk to fill any gaps and it's barely noticable from a distance of about.....Oh 20feet ;)
