surround cables - the same or different?
Discussion in 'Home Cinema Speakers' started by simon1967, Apr 27, 2003.
  1. simon1967
    simon1967
    Jul 1, 2002
    616
    SE London/Kent
    +7
    I have the builders in my house at the moment and want to get the surround speaker cabling installed so that it is hidden in the wall and behind the coving.
    The front & surround speakers have not been decided but it will be a 7.1 set up. The possibilities are M&K MPS2510 fronts / 1510 surrounds, Monitor Audio Golds or Silvers, Ruarks or something completely different. :confused:
    My questions are:
    1. I have Cable Talk 3.1 biwire from my old set-up. Is this good enough for the above speakers?
    2. I may try some multi channel music so if I biwire the fronts, should I biwire the surrounds?
    3. Can I use mix and match cables so that I reuse my existing Cable Talk 3.1 for the fronts.
    4. The room is 17ft x 20ft so there will be some long runs for 4 speakers so suggestions and prices for surround cables?
    Thanks all
    simon
  2. Sunday Ironfoot
    Sunday Ironfoot
    I'm just curious, but are you sure it's wise to hide away the cable so that you can't get at it in the future (in case you want to upgrade)?
  3. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    If you put the cable inside some tubing before it goes in the wall, then you can still upgrade. Just attach the new cable to the old, and pull it through.
    You just need to avoid any corners along the cable run. Make them rounded.
  4. Johndm
    Johndm
    Jan 25, 2003
    1,804
    Bedford UK
    +56
    I used fairly decent biwire cable to the main fronts, but wired the rears and centre rears with mains cable.......sounds fine..:D
    Couldn't bring myself to spend the approx £350 it would have cost to match surround cables with the mains! Although to get a little 'feelgood factor' I kept all rear cables the same length.(discussed elsewhere on this forum)
  5. simon1967
    simon1967
    Jul 1, 2002
    616
    SE London/Kent
    +7
    I'm not that bothered about upgrading the cables because the positioning of the surround speakers will not change (unless they bring out 8/9/10.1 :eek: ). I will be at the house for at least the next 4/5 years so won't be touching the cables once they are in.
    If I can put plastic tubing into the wall, I'll get the builders to do that.
    Bearing in mind that the rears MAY be used for multi channel music so are using the full-range of the speakers, I don't mind getting some half-decent cables but any advice on where to go from here - more cable talk 3.1 or QED silver anniversary (been browsing through the old archives....).
    Thanks again
    simon
  6. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    MPS1510 aren't biwireable but I'm not sure about the rest.
    I use Silver Anniversary on my 1510's
