Surround And Denon 1905 Questions
Discussion in 'AV Receivers & Amplifiers' started by Garrett, Nov 19, 2004.
Tags:
  1. Garrett
    Garrett
    Apr 21, 2001
    32,326
    2
    167
    The best thief you’ll never see.
    +4,229
    I just got a Denon 1905 upgrading from a just pro-logic.
    I’m using my own amp for the front speakers.
    I have set up the test tone for the front, centre, surround, sub, and surround L&R.
    I have connected using a coaxial cable to the receiver and I’m playing a DTS dvd but I’m only getting sound from my front speakers and sub. The receiver must be working as it is the only one receiving the sound input also using the volume controlled on it alters the front speakers volume and the sub.
    The disply is showing Direct DVD and Digital.
  2. Arcangel
    Arcangel
    Press the Dolby/DTS button (might be labelled differently) on the Amp or Remote as it sounds like you have it in DIRECT mode rather than a Surround Mode.
  3. Garrett
    Garrett
    Apr 21, 2001
    32,326
    2
    167
    +4,229
    :smashin: Thanks I got it was the Standard or Direct button just forgot I have been play different DVD and got carried away for a while then answered the post. :blush:
