Surround advice please...
Discussion in 'Home Cinema Speakers' started by kevshed, May 16, 2004.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,223
    48
    bournemouth
    +85
    hi guys, not posted on a while, as been busy with a house move etc.... which leads to me my problem.
    In my setup, my front stage is 700 series b&w.... but i have a surround problem.
    My sofa, like many needs to go directly on the back wall. so i have a positioning problem..
    My options are:
    1- Fit some surrounds above the sofa... in which case, im leaning towards the b&w DS7's dipoles?
    2 - have bookshelfs on stands, firing in from lef/right next to the sofa.
    3 - or... have the DS7's wall mounted next to the sofa firing in from the left/right.
    I think i know which way im headed on this, but inputs always appreciated.
    FYI these are exclusivly for movies - not multichannel music listening....
    Thx
    Kev
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I have exactly the same problems as you. I use your #3 as the solution. It works well. Im waiting till I can fit my other bipolars above the sofa to see if that improves the sound:D
  3. kevshed
    kevshed
    Oct 30, 2002
    1,223
    48
    bournemouth
    +85
    thanks for the reply... there are many with the same problem, but i get conflicting advice from dealers all over the place... not really too sure which way to go. Im heading towards the option 3 above..... when are you going to try option 2.. would be interested in your results.
    thx
    Kev
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I'm sure that people also get conflicting advice on the forum too :D
    If it helps I also have mine a la option 3
  5. kevshed
    kevshed
    Oct 30, 2002
    1,223
    48
    bournemouth
    +85
    option 3 getting the favour so far then :) Thx
