Hawklan
I've just purchased some Surround-55 M&K II Tripoles to go with my 750 M&K II THX selects (Left, Centre and Right) and I need some help with the placement
To keep them away from my kids I have placed them higher than head height basically 4 inches or so below the ceiling - Is this OK?
My real question is - On reading the manual when you place these speakers above head hight you need to turn them upside down so that the tweeter is on the bottom. The speakers are directional and designed to be dedicated left and right (due to the tweeters firing angles). Since I have turned them upside down do I now switch the left and right around or leave them as they are?
Many thanks
Ronnie
Many thanks
Ronnie
