Surrond Sound Connections
Discussion in 'Cables & Switches' started by krspa9, Dec 19, 2006.
  1. krspa9
    krspa9
    May 24, 2006
    38
    Hi, I've recently purchased a home theatre system and wanted some advice on how to connect other devices to it. I currently have Sky and a DVD recorder but am not sure how to connect these via the surrond sound system.
    Having read the instructions it seems that I need to connect each device via an audio cable and a video cable. Can someone advise me on which cables are best to use or point me in the direction of some setup guides.
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
    Can you help everyone to help you by telling us what kit you have, make and model.
    SKY what, basic, +, HD etc
  3. krspa9
    krspa9
    May 24, 2006
    38
    I just have a normal sky box. I've just bought Sony DAVX1G surround sound system. I have a 40" Sony Bravia KDL40V2000U and also a Sony DVD recorder with hard drive. In work at the moment and can't remember the model no. I think its RDR-HX510 with 80GB hd.
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
    Sky direct to TV with SCART cable (Quality), standard stereo RCA/phono cable for sound, you need Sky+ or SKYHD to get real surround via optical.
    DVD recorder Component video out set to progressive direct to TV, need a cable like this http://www.tvcables.co.uk/cgi-bin/tvcables/CP001.html + http://www.tvcables.co.uk/cgi-bin/tvcables/PH002.html for the audio from DVD to TV. Connect http://www.tvcables.co.uk/cgi-bin/tvcables/PH400.html from DVD to co-ax input on surround system, you may have to assign the input on the surround system to an input, example "Digital in X to DVD", see your instructions.
    That leaves an optical input for the future which can be SKY+ of SKYHD.
