Supra component cable? And length?
Discussion in 'Plasma TVs Forum' started by peterakastorm, Sep 3, 2005.
  1. peterakastorm
    peterakastorm
    The Supra AV3 cable has won a best buy price, in Whats Hii, og someting, so it's ok to go with that cable? And does 2 vs. 3 metres, has anything to say, performance wise?
  2. peterakastorm
    peterakastorm
    Nobody knows?
  3. Eitzel
    Eitzel
    Nov 3, 2004
    663
    46
    Top Secret-Anyone coming anywhere near my Pioneer
    +145
    I have a 1m length of the cable and it's great. It is available in a 3m version so it should be OK to use.
  4. peterakastorm
    peterakastorm
    Ok, sounds good to hear!
  5. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    I would think shorter is better.
    The minimum to do the job is best IMO.
  6. peterakastorm
    peterakastorm
    Yeah, shorter sould be better, but 2 vs. 3 meters? Has that anyting to say?
  7. shyewei
    shyewei
    Dec 11, 2002
    5,384
    London
    +191
    Very nice cables!
    Friend of mine has a 2m supra component cable and I have the QED P-CV1 (also an award winner). Must admit overall we both preferred the supra cable which had a more "cinematic" picture with DVDs, can't describe it better than that.
    The QED cable had a more "detailed" picture, but the colours weren't as good. That was with the "old" cable. Haven't had a chance to compare the supra with the new QED cable.
    Hope that helps,
    Shye
  8. peterakastorm
    peterakastorm
    Thanks, shy, helps alot.
    But what about the 2 vs. 3 meter thing? I'm gonna wall mount my plasma, and the reciever isn't placed entirely under the screen... a little to the left actually... and I don't think 3 metres will be enough... so will there be any noticable difference in quality?
  9. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    Try asking this in the Cables forum as well, you may get more responses over there.
  10. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    +1,921
    Just been looking at DVI cables and the site said no more than 7.5 m for DVI standards.Not the same, I know, but the component cable is more basic (being a single cable).Interference becomes a problem the longer you go (with any decent shielding it's not a problem), but I think a few metres will not result in signal loss.
    I guess you'll be safe with longer than 3m, just buy reasonable quality.
    HTH
  11. peterakastorm
    peterakastorm
    Actually, I meant that 2 meters wouldn't be enough, but I've just mesured, and I think that the 2 metres will be enough, so no hazzle ;)
  12. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    +1,921
    Buy the 3m if it's that close. It won't be a problem, IMHO :smashin:
