Question Superslim & tilting wall bracket - 55” & 35kg
wizbongre
We’re doing some decorating which means I’m moving our existing Plasma between rooms. To make it work in the new room it needs to be wall mounted.
I’m looking for an ultra thin (ideally ~20mm) deep bracket that also easily tilts and can support the ~35kg weight.
Basically, I need a Vogel Thin 525 that can support more than 25kg!
Any suggestions?
wizbongre
Bump - anyone?!
Trending threads
Trending threads
