Superman
Discussion in 'Movie Forum' started by h0l1yw0od, Mar 1, 2001.
  1. h0l1yw0od
    h0l1yw0od
    Nov 16, 2000
    477
    +13
    I've looked and asked in several places but i cannot seem to find a definate answer so...
    Does anyone know if the Superman Box Set caries the Special Edition of Superman The Movie?
    "People think I'm crazy, in which case I'm f****d and nobody wants to work with me, Or they think I'm faking to draw a psycho pension, in which case I'm f****d and nobody wants to work with me. Basically, I'm f****d."
  2. mysteriousjimmy
    mysteriousjimmy
    good question....
    I just had a look on dvdboxoffice and the boxset lists Superman:The Movie running time 125mins and then checked the listing for Superman:The Movie SE running time 151mins...
    I hope it is the special edition as I have the boxset on preorder at the moment...
    mysteriousjimmy's home cinema
  3. Mark P
    Mark P
    check out DC-DVD website guys, it states that the box set DOES include the special edition 155mins disk with all the added extras. theres a good pre -order price as well(£51). For a reg 1, 4 disk box set it sounds good to me. think i'll place myself an order.
    mark p
  4. mysteriousjimmy
    mysteriousjimmy
    thanks for the info Mark P, I order all my R1's through ABSound ( better exchange rate with the $AUS to $CDN) and they don't have any info about the discs's..
