Superhub 3
Discussion in 'PC Gaming & Rigs' started by Theydon Bois, Dec 6, 2018.
  1. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,162
    Sauf Lunden
    +7,222
    Please tell me I am not the only one that has a pile of garbage SH3 router that constantly drops the internet yet Virigin says there are no problems in my area, yet Edge is full of tabs that say 'Click Me, Connection problem'
    What have you done about it? Modem mode and buy a new router? Gone back to SH2? Something else? Whats the point of upto 350m/s if it doesnt work in the first place?
  2. aslird
    aslird
    Sep 8, 2011
    6,031
    +4,226
    My SH3 works fine with Chrome, never use Edge so cannot comment with that, - the Wifi can be a bit weak however at the top of the house.
  3. Delvey
    Delvey
    Jul 20, 2008
    8,905
    Manchester
    +2,728
    As above, mine works fine.
    I did have to change the wireless channel to something other than Auto however, as wifi get dropping on the auto setting
  4. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,162
    Sauf Lunden
    +7,222
    Sorry, I meant it drops internet connection constantly. When it does, it opens a tab in your default browser to say something has gone wrong on any device connected via ethernet. Edge is the default browser on my HTPC, but I hardly use it for the web (bar netflix) so it has loads of tabs with the error message.
    I have a few devices wired to the router, one to a HomePlug, then multiple on wireless.
    It drops constantly, and is really bloody annoying.
  5. beckford
    beckford
    Oct 3, 2006
    636
    +336
    I'm still on Superhub 2 but turned it into "Modem only Mode" and now use a Netgear X6 (R8000). Better connectivity, both wired and wireless :smashin:. Not noticed any drops and its been in since August.
  6. oculuspioneer
    oculuspioneer
    May 27, 2016
    10
    North West
    +7
    What does the log show on the superhub 3, does that show the wan is dropping? Also what are the power levels.
  7. Arcam_boy
    Arcam_boy
    Jun 13, 2006
    11,945
    2
    Birmingham
    +2,304
    @Theydon Bois
    Is it your wifi dropping out or things connected (wired) to the SH3?
    I've recently moved over to Virgin and my devices connected to the ethernet ports kept dropping out. I had Virgin come out and they said there wasn't an issue even though google suggests otherwise. I had a new SH3 fitted anyway but that didn't resolve the issue.
    After lots more faffing and trial and error it was my wired Sonos products which were conflicting and causing the issue. They're all now running wireless and its been perfect ever since!!
