The superdrive no longer appears in my system profiler and will not work. I have re-set the PRAM, done the battery thing (some kind of re-set - can't quite recall what it is called). Will try the install disc tonight but:
Does anyone have any tips for fixing a UBMBP Superdrive?
If I can't fix this it will be off to Apple who have already quoted 7 business days to fix but what I forgot to ask them is, if I have to bring the machine in do they keep the machine or can they order the part in, I keep the machine and then when the part arrives they can replace it there and then?
I really do not want to be without the machine even for a day.
Can anyone help?
Can anyone help?
