Superbit sale on ChoicesDirect, should I bother upgrading?
Discussion in 'Movie Forum' started by MyMateJohn, Apr 30, 2003.
  1. MyMateJohn
    MyMateJohn
    I have a double-sided Gattaca R3, should I upgrade to the Superbit R2?
    I've also got the standard R2 Crouching Tiger. There's one thing that I noticed, in the first sword fight scene with Jade Fox, and one or two other kung fu scenes I notice "blurring" due to the sheer speed of the fighting. When I saw it in the cinema I'm sure there wasn't any "blur".
    Could it be possible the Superbit version might eliminate this effect?
    Or could it be my DVD player producing such a effect?
  2. nathan_silly
    nathan_silly
    What DVD player, and have you a 100hz set?
  3. MyMateJohn
    MyMateJohn
    Haven't got a 100Hz, but I've played CTHD on a Sanyo "Home Cinema System" using Scart and an Aiwa multi-region system bought from Brunei using component in (although both systems use different TVs), and I spot the effect both times.
    I suppose my CTHD problem is an isolated case?
