Superbit DVD's.
Discussion in 'Movie Forum' started by penfold, Aug 15, 2002.
  1. penfold
    penfold
    So, what's all the fuss then? What is actually different that makes these films superior, and do I need particular equipment/configuration to watch/optimise them?
    cheers,
    Dan.
  2. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    You don't need any special equipment - any standard DVD player will fit the bill. Superbit DVDs strip out all the "extras" we now associate with DVDs leaving as much space as possible to record the movie and soundtrack at the highest bitrates possible. In theory giving the best possible sound and vision quality.
    There is however some debate as to whether this is the case - as I have some special edition DVDs that are recorded at a higher bitrate than the so called superbit discs
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    As I unserstand it, it is the filtering used with Superbits that make them special, high bit rates on there own dont count for much.
  4. gimli
    gimli
    Superbits are worth buying if you're not into extras especially if you have a decent sound system and large screen.
