superbit dvd
Discussion in 'Movie Forum' started by steve1, Jan 21, 2008.
  1. steve1
    steve1
    Jan 5, 2002
    1,277
    48
    maidstone
    +33
    not sure if you can still buy them now. but i use to buy a lot of superbit dvd.i do recall they were much better picture than sd dvd.any way was wondering how they would compare now.to hd/ blueray
  2. DrPepper
    DrPepper
    Oct 2, 2001
    3,420
    Barking Essex
    +282
  3. bosque
    bosque
    Oct 19, 2006
    6,004
    +554
    superbit was a brand-name and the picture quality on the discs was no better than SD DVD. In fact, the superbit Region 1 Panic Room was worse.
  4. Ethan2000
    Ethan2000
    Jan 20, 2006
    945
    Hereford
    +65
    I'm sure the superbit dvd's were a lot less compressed than the standard dvd and most of them were loads better than their normal dvd counter-part.
  5. McFaber
    McFaber
    Aug 23, 2006
    2,193
    +135
    I've got several superbits, although mostly region 1s.
    I'd say thery're better than standard SD dvd, it's not a night & day difference, there is a difference imo.... Plus you got DTS as standard....:thumbsup:
  6. bosque
    bosque
    Oct 19, 2006
    6,004
    +554
    Possibly a noticeable improvement on projectors and 100" screens but on 32" - 40" screen impossible to detect any difference.
  7. steve1
    steve1
    Jan 5, 2002
    1,277
    48
    maidstone
    +33
    i thought id mention superbit as i had hollow man on superbit looked great on my old denon dvd player
  8. raigraphixs
    raigraphixs
    Jul 11, 2001
    64,701
    +25,168
    put fifth element on the other day, and straight away i noticed how clean and sharp the image looked compared to alot of recent releases.
  9. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    IMHO it was a marketing scam, the bitrate was no better that normal SD discs. Play it on a PC and check....
  10. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
  11. Mark_a
    Mark_a
    May 27, 2005
    3,242
    +696
    Bit rate and compression are not clear cut indicators of quality. The quality and the care taken in the transfer, and the quality of the original film that it's transferred from, and even the content of the film itself, are all as important when it comes to creating a superior DVD.
    There are quite a few examples where high bit rates still result in very mediocre DVDs. Having said that, Superbit discs can generally be said to be of at least good quality. Which isn't to say that there aren't plenty of non-superbit DVDs that are at least as good, if not better. So, as with many things, mostly marketing bull plus a grain or two of truth.
    Regards
    Mark
  12. steve1
    steve1
    Jan 5, 2002
    1,277
    48
    maidstone
    +33
    just wanted to say superbit dvd was a higher bitrate than sd. you always got a dts soundtrack. and the dvd sleeve looked great as well.
  13. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    Lol, this quote, if it were taken literally, would be the end of HD transfers. They are done in the same way.. so how can you say that Superbit DVD will not be superior if the bitrate is higher?
  14. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    :rolleyes:
    Not that old chestnut again!
    Click here.
  15. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    Even though Superbit was never better than a standard DVD, it was a good idea that should have been put into production properly by someone. If Moulin Rouge can get more information out of a film, then so can a Superbit idea, without the extras of course, which seem to go against the idea.
  16. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    It was. By Paramount, Warner, Universal, Fox, Disney, etc, etc. It's called DVD.
  17. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    So.. why did you say that Moulin Rouge was better quality then? That was also a DVD.....
  18. Mark_a
    Mark_a
    May 27, 2005
    3,242
    +696
    No it wouldn't. HD is in no way simply a matter of higher bitrates.
    No they're not.
    Because it's true. If you knew anything about the technical side of DVD mastering then you'd know that and wouldn't make such strange, ill informed comments.
    Regards
    Mark
  19. Geoff_D
    Geoff_D
    Feb 14, 2005
    11,868
    167
    Spider Skull Island
    +5,811
    Speak for yourself. I could tell Superbits apart on my previous TV, a 32", let alone my current display (43"). I bought a fair few too, not because of the hype aimed at the ill-informed (like the poor souls who still seem to think that they're not standard DVDs) but because they were better than what Sony dished up first time around.
  20. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    I was thinking that Bits were Pixels, and that a bitrate was a frequency at which you would send these pixels to a screen, and that HD would require a high frequency, and more pixels, and that a High Bitrate DVD would be less compacted than low bitrate, and the more pixels you can send to a screen without compression, the more accurate transition from Master to transfer. I don't know.. just guessing from being a graphic artist.
  21. Helicon
    Helicon
    Apr 4, 2005
    5,016
    +261
    True. The only Superbit disc i have that i'm actually impressed with is Desperado. Other than that, dts is their only benefit.
  22. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    :confused:
    Yes, made by Fox. Not a Superbit release. Which was my point.
  23. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    Why can't you see that your point also reflects that higher bitrates means better picture? So if a company remade movies with higher bitrates they would look better. You think that anyone would not call this a DVD? You think that people would not buy movies with improved quality?
    I just bought Terminator Ultimate Edition.. Enhanced Digital Transfer. do you not think there is a market for improved picture DVD's?
    So I said.. "Why doesn't someone actually do what Superbit suggests?" and you reply.. "They are called DVD's."... well.. that is a strange reply, being as you class all DVD's as a single quality picture, yet make an entire thread about the pictures all being different.
  24. bosque
    bosque
    Oct 19, 2006
    6,004
    +554
    Don't know if you've ever bought re-mastered DVDs but they tend to be better quality then the DVD on its first release. That's all superbits were, remastered DVDs, but Sony tried to fool the public into thinking their discs were higher quality than their rivals, and then withdrew the brand name when it was clear that only a few people were taken in by this hogwash.
  25. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Nowhere, either here or on the thread linked to, have I stated anything so ridiculous as that I "...class all DVD's as a single quality picture..."
    Did you bother to read what was in the link?
  26. figoagogo
    figoagogo
    Mar 29, 2005
    8,188
    +579
    I have still yet to watch my Das Boot 2disc Superbit - not sure why I bought it, perhaps for the novelty of having to change DVD half way through the moive :eek:
    I also have Spiderman 1 and 2 on superbit, but never compared to other verisons.
    I did like the idea behind superbit i.e. get rid of the extras and annoying animated menus, and use the extra space for movie/sound, but if the mastering wasn't good in the first place then it doesn't really matter, whether it was on Superbit or "normal" DVD.
    I am sure there are examples of better and worse Superbits vs DVD - but it is important to remember that Superbit was just a brand using the normal DVD format - no wizardry involved.
  27. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    Well.. any hope for them bringing them back is pointless anyway with HD now available. Plus, most of my films are good quality anyway. So there's no point in discussing the matter further.
  28. figoagogo
    figoagogo
    Mar 29, 2005
    8,188
    +579
    How about Bluray Superbit ;)
  29. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    Well... House Of Wax needs remastering already.. It's pretty bad really, how they can make such poor quality HD movies. I'm sure that I've got DVD's that are better Quality than House Of Wax.
  30. figoagogo
    figoagogo
    Mar 29, 2005
    8,188
    +579
    and so the cycle continues - no doubt a lot of HD discs are not done at their absolute best - and the "remastered-directors cut-special edition-superbit(tm)" version get released.
