Super super bit?
Discussion in 'Movie Forum' started by captaindobie, Feb 2, 2003.
  1. captaindobie
    captaindobie
    Apr 17, 2002
    580
    Scotland
    +18
    Watching the U2 best of DVD the other day and was amazed to see my sony dvd record a bitrate of over 1500kbps!. Is this a record for a standard DVD? how does this bitrate thing actually work. Most DVD's that i have watched seem to have a bitrates starting at 192kbps (x files) up to 500kbps (although Moulin Rouge may be slightly higher)
  2. Confucius
    Confucius
    Feb 1, 2001
    2,103
    Oxford
    +90
    Max bit rate of DVD is 10.08 Mbps
    If you're talking of audio only then DTS (on DVD) can be from 64 to 1536 Kbps, typical values are 754.5 or 1509.25 kbps.
    DD can be from 64 to 448 kbps, typically DD 2.0 will be 192 kbps.
  3. captaindobie
    captaindobie
    Apr 17, 2002
    580
    Scotland
    +18
    Thanks for the info. I think i was getting a little confused betweend audo and video bitrates. That's what i like about this forum, you learn something new everyday!:smashin:
