Super simple question
D
drumline21
ok. i just need to have someone else answer this for me. i already know the answer but they dont believe me. Can you put a new bulb in a dlp projector and get a better resolution?
laserdave
No the only difference you will see is a change in colour balance if the previous lamp had 800-1000 hrs on it.
Resolution is fixed at the chip/lcd engine.
D
drumline21
thank you. know i can tell her that she is very very wrong.
Similar threads
