Super Nintendo Game pak connectors need cleaning??
Discussion in 'Nintendo Forums' started by w3dal, Jan 14, 2004.
  1. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    Hi All,
    I moved recently and found my Mint Snes which has proberly been in the loft unused for 4-5 years.
    Anyway i started to play Mario Cart again on it over Christmas and sometimes it takes the games a couple of times to load and have to blow the Game Paks and then they work.
    Just wondered if anyone knew which i could use to clean the connectors on the Snes and maybe the game paks themselves.
    I would say it boots games 90% of the time but im putting this up for sale soon and want it working 100%
    Its been in its original box so is there anything i can do, or do u think its not booting due to its age??
    Right off for some Street Fighter 2 Turbo action - ;0)
    Dal
  2. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    Several weeks ago, I bought a few collections of old console games for a friend's Christmas present. Scarily at first, most of them wouldn't work in either my own console or the one that I'd just bought.
    A quick wipe of the cartridge contacts, using isopropanol (isopropyl alchohol, 'tape cleaning fluid') and a cotton bud, gave a dozen 'as new' games. Yep, they all work now. Just remember to put them aside for a while, to let the alcohol evaporate.
    If you need isopropanol, away from tape cleaning fluid and similar, I have read that you can buy it from chemists. I haven't yet had to check, but it'll be worth asking :smashin:
  3. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    Hi Andy,
    Thanks for the reply. One of my GF's bestmates works in a Chemist so i will ask her to get me some from her place (if they do it that is)
    Im not im sure the old man has some tape fluid somewhere around his house i could use.
    Thanks Again.
    Dal
  4. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,277
    2
    167
    The Wheldon Road end!
    +8,349
    Hi Dal,
    Electrolube switch cleaner works a treat as well, comes in an aerosol can and you squirt it onto the contacts and rub off the dirt with lint free cloth - should see the crap that comes off them!:eek:
    GTHOM3
  5. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,275
    38
    Scotland
    +20
    Would lighter fLuid as Ive heard of people using it to clean scalextrix contacts?
  6. monkeylegs
    monkeylegs
    Dec 10, 2002
    79
    Barnstaple, Devon
    I agree Electrolube switch cleaner is the best way to go, Ive used it on all my game packs and it brings them up a treat!! The only problem I have is getting the yellowing (caused by smoking) off the main body of the game pack. If anyone has any suggestions on how to remove this I would be realy gratefull.:D
  7. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    Hi Guys,
    Cheers for the info i shall get some of that at the weekend. My SNES has gone a darker colour then when it was new. I believe its now down to smoke as i dont smoke but because the unit is so old. My Amiga did the same thing.
    Still a great machine.
    Thanks Again
    Dal
  8. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,277
    2
    167
    +8,349
    Smoke stains should come off with a good cleaner, maybe even with vineger. It may or may not be smoke as white plastic yellow with age anyway. I guess if you dip a cloth in vinegar and run an area of the game pack and the cloth goes yellow then it'll be smoke. If you use vinegar then make sure you wipe it down with a damp cloth afterwards and don't get any on the contacts as it's corrosive.
