Hi guys, I've got a few questions regarding the Sumvision SV-1000:
1) I've had an absolute nightmare trying to make a DVD, it was working fine, I renamed the titles and it all seemed great, turned the machine off, and when I turned it back on again it just won't read the disc, I tried finalizing it but still no luck. Does it support DVD-R?
2) I've unfortunately lost the manual, is there anyway to find out what the different recording modes (HQ, SP, LP etc) offer in terms of quality and how many hours you can fit onto a disk? I'm recording from Sky+ via a non RGB scart cable so was thinking I'd use either SP or LP.
3) How do I know when I should finalize the disks? If I don't finalize them are they going to be completely useless or are there ways of finalizing them maybe on the PC or similar?
4) Is there anyway to set it so by default it doesn't display the time left of the DVD? I know you can fix this by pressing the 'OSD' button a few times but it'd be great if it wasn't displayed at all.
Thanks!
Thanks!
