Sumvision N820 Divx dvd player
Discussion in 'Blu-ray & DVD Players & Recorders' started by ace420, Nov 13, 2004.
  1. ace420
    ace420
    Can anyone tell me a bit about this DVD player please, it plays divx files, but how good is it and can it play xvid files etc. The progressive scan interests me as my current dvd player does not seem to have it. any help would be much appreciated.
  2. technovorgin
    technovorgin
    Jun 16, 2004
    226
    Leeds/Wakefield border
    its a budget player mate i have the 808 and it seems to work fine on prog scan into my plasma heres the spec on the n82o (£45 inc vat at my local suplier) & its multiregion with remote code
    Compatible with DVD/SVCD/VCD/CD/MP3/CD-R/CD-RW/JPEG/CD+G/MPEG4 and Kodak Picture CD discs.
    Dolby Digital AC-3 decoder,5.1-channel audio output.
    DTS Digital output.
    Digital audio coaxial output.
    Composite video output,s-video output and YUV output.
    Y/Pb/Pr Progressive scan output.
    SCART output
    32 subtitles,multiple angles and 8 languages supporting.
    4:3/16:9 picture conversion.
    Parental lock setting.
    PAL/NTSC compatible.
    Full functional remote control.
    Product Dimensions:L:430mm W: 275mm H:38mm
    Weight:2.8kg
  3. pittatown
    pittatown
    I have one of these unit & pleased in general for the price - the only thing is
    some dvd's have no dialoug, only background audio - does anybody know if theres a setting to change or if other units do this? :confused:
  4. MKPatrick
    MKPatrick
    Dec 11, 2003
    336
    Buckinghamshire
    +10
    Sounds like you've not selected the downmix facility. How are you connecting the dvd player to your sound system? If you only have basic stereo sound you need to ensure that the 5.1 sound is being downmixed to stereo.
    What audio outputs are on the back of the player? Which are you using and connected to what?
    Patrick
  5. dev1014u
    dev1014u
    Can anyone tell me if this unit has mic input as one site says it has but cant seem to find out from any retailer
