Hi Stephen I wonder if you can advise re the shortcuts feature for this?
I have tried contacting sumvision support on several occassions but they are worse than dreadful.
I have ultimately worked out how to setup specific shortcuts for the folders/shares I have on my NAS, however the process took a while and rather than modifying the entries when I've used the green button menu's MODIFY option it has created addition copies/entries.
I now can't seem to delete these even with the Green button menu's DELETE option.
Do you have any ideas how to fix this as I don't want to have to do a factory reset and start having to input all this again?
Many thanks for your help!
How do you create directory short cuts? I have a few NAS's so browsing into each sub-directory is a pain.[/QUOTE]
No problem so far, can't complain for £40. Can't get any wifi from other side of the house though
Little bit sluggish in menu option
